Icom IC-2720H dual band stöð SELT
ossgrandi
Skráður: 20.mar 2012, 11:29
Fullt nafn: Örn Gunnþórsson
Postfrá ossgrandi » 20.mar 2012, 12:46
Til sölu Icom IC-2720H dual band VHF/UHF radíóamatörastöð
Stöðin er forritanleg í tölvu og býður upp á endalausa notkunarmöguleika, fronturinn er laus þannig að stöðin sjálf getur verið hvar sem er í bílnum og ekki þarf að gata mælaborðið, aukahátalari og sogskálabrakket fyrir frontinn (hægt að smella honum á framrúðuna) og leiðbeiningamanual fylgir með.
mæli með að athuga google til að kynna sér málið betur.
hér er eitthvað af upplýsingum frá Icom:
V/V, U/U simultaneous receive capability
The IC-2720H is a unique dual band mobile, providing VHF/VHF,
UHF/UHF simultaneous receive capability along with VHF/UHF full
duplex operation. Simple touch of a button changes the transmit band.
Independent controls for each band
Operating two bands simultaneously is very simple with Icom’s
symmetric layout with a wide LCD display showing both band settings
in an easy to read side by side format. The IC-2720H provides
separate tuning, volume, squelch knobs and function buttons for
the left and right side bands. Also, listen to both bands independently
through separate left and right band audio jacks.
Dynamic Memory Scan (DMS)
With 212 memory channels, Icom’s exclusive Dynamic Memory
Scan system gives you flexibility
over your scanning lists, fully customizable in 10 banks.
Wideband receiver
Keep on top of what is happening with the IC-2720H’s wideband
receiver. Covering from 118–549 and 810–999MHz*, you will be
able to listen to almost any communications!
HM-133, remote control microphone
The Icom exclusive “Hot keys” (F1/F2) memorize
the most commonly used transceiver settings.
DTCS and CTCSS
The IC-2720H incorporates 104×2 DTCS and 50
CTCSS tone codes along with a tone scan function.
Don’t miss out on communications because
of not having the proper type of “tones”! The
“pocket beep”feature gives you an audible and
visible indicator of an incoming call.
Compact, remote controller
The controller with the 3.5m (11.5’) separation cable is an easy to
install two pieces configuration. This configuration offers the flexibility
of mounting the controller while placing the main unit in an outof-
the-way location without any additional cost. Microphone jacks
are mounted both on the controller and main unit of the radio!
And more…
• 10dB RF attenuator • Selectable squelch delay
• 9600bps packet data terminal (mini-DIN 6-pin connector)
• Optional MB-85 allows you to mount the controller to the main unit
• 14 DTMF memory channels (24 digits)
• Sub band auto mute function • MOS-FET power amplifier
• Weather Alert* • Auto repeater function*
• Wide/narrow channel spacing*
Output power : VHF 50W, 15W typ., 5W typ. selectable
UHF 35W, 15W typ., 5W typ. selectable
. Max. frequency deviation : }5.0kHz (wide), }2.5kHz (narrow)
. Spurious emissions : Less than .60dB
. Microphone impedance : 600Ħ (8-pin modular jack)
. Receive system : Double conversion superheterodyne
. Intermediate frequencies : 1st 38.85/46.05MHz
(Left/right side band) 2nd 450/455kHz
. Sensitivity (at 12dB SINAD) : Less than 0.18ƒÊV
. Squelch sensitivity : Less than 0.13ƒÊV (at threshold)
. Selectivity (Wide/Narrow*) : More than 12/6kHz at .6dB
(* U.S.A. version only) Less than 30/20kHz at .60dB
. Spurious rejection ratio : More than 60dB
. Audio output (at 13.8V DC) : More than 2.4W at 10% distortion with an 8Ħ load
. Ext. speaker connector : 2-conductor 3.5 (d) mm (1.8")/8Ħ
Vil sjá lítinn 30 þús kall fyrir allt þetta eða svakalega gott tilboð
Örn
8628661
hér er vídjó af eins stöð
[youtube]W2hRRXDLLtU[/youtube]
Síðast breytt af ossgrandi þann 21.mar 2012, 18:38, breytt 1 sinni samtals.
hobo
Skráður: 31.jan 2010, 17:44
Fullt nafn: Hörður Bjarnason
Re: Icom IC-2720H dual band stöð
Postfrá hobo » 20.mar 2012, 15:50
Lagaði vídjóið fyrir þig.
kv Hörður póststjóri.
ossgrandi
Postfrá ossgrandi » 21.mar 2012, 18:38
takk kærlega Hörður. þetta varð til þess að stöðin seldist.
