! SELDUR ! 1993 4th Gen Camaro Z28 LT1-LT4 Hotcam
deadlift83
Skráður: 26.des 2011, 18:59
Fullt nafn: Benedikt Magnússon
Postfrá deadlift83 » 26.des 2011, 19:01
!!!! - SELDUR - !!!!
1993 Chevrolet camaro Z28
Details um mótor:
Eagle LT1 all forged 4340 383 stroker assembly 4340 forged
1 piece rear main seal crank, 4340 H beam 6" rods Total Seal
plasma moly file fit rings, JE pins, keepers and SRP forged
pistons 10/1 compression with a 61cc chamber, Clevite 77
H series rod & main bearings AFR 1031 195cc LT4 street head
with 61cc chamber Spring upgrade to handle .600" lift on AFR 1031
Comp Cam #07-306-8 cam
Comp Cam #850-16 lifters
Comp Cam #7608-16 pushrods
GM performance parts LT1 timing set
M-55HV Melling oil pump high volume
Pick-up for stock LT1 pan
ARP 134-5601 4 bolt main studs
ARP 134-3701 head bolt set
freeze plugs and cam bearings
ARP 230-7002 oil pump stud kit
ARP 134-7901 oil pump driveshaft kit
ARP 134-2501 balancer bolt kit
ARP 234-1001 Cam bolt kit
ARP 534-9801 engine and accessories fastener kit
Fel-Pro HS9966 & CS9966 complete engine gasket sets
professional assembly and machining to include
balancing, decking, magnaflux, R&R cam bearings
Freeze plugs, align hone, bore and hone cylinders
file fit rings, fit pistons, fit pins and keepers, mock
up for stroker kit and clearance accordingly
The compression of the engine is 9.8/1
Cam specs:
224 degrees duration on the intake @ .050 lift
230 degrees duration on the exhaust @ .050 lift
Lobe lift of .3353" on the intake (.503" with 1.5/1 rockers & .536 with
1.6/1 rockers)
lobe lift of .3400" on the exhaust (.510" with 1.5/1 rockers & .544 with
1.6/1rockers)
lobe separation is 112 degrees with an intake centerline of 108 degrees
rocker roller arms
58MM thottlebody
Síðast breytt af deadlift83 þann 02.feb 2012, 23:30, breytt 2 sinnum samtals.
deadlift83
Re: 1993 4th Gen Camaro Z28 LT1-LT4 Hotcam
Postfrá deadlift83 » 28.des 2011, 08:47
ttt
deadlift83
Postfrá deadlift83 » 30.des 2011, 23:13
ttt
deadlift83
Postfrá deadlift83 » 02.jan 2012, 21:25
ttt
Til baka á “Önnur farartæki”
