NP241D HD
Re: NP241D HD
Átil millikassa úr Dodge Ram 1500 2005 sem var með 5,7 Hemi númerið á honum er NP-241 D s 8424601
Re: NP241D HD
duramax wrote:Átil millikassa úr Dodge Ram 1500 2005 sem var með 5,7 Hemi númerið á honum er NP-241 D s 8424601
Það er ekki alveg það sama, en mjög nálægt því.
The NV241D is a heavier duty Dodge version of the 241, with a larger input shaft and larger bearings to withstand the torque of the V10 and diesel engines.
The NV241HD, an option on Ram 2500's and standard on Ram 3500's built after 1998, has a stronger case and wider drive chain to better withstand the shock of snow plow service, a PTO cover and drive gear, and an extra bearing to support the thrust to the main shaft created by a PTO adapter.
Sjá hér;
http://dodgeram.org/tech/specs/tranfer_case.htm
