Ts: Gormar fyrir JEEP 6" hækkun
Rikki
Skráður: 21.nóv 2014, 23:49
Fullt nafn: Rikardur Már Pétursson
Postfrá Rikki » 30.mar 2015, 22:11
Til sölu gormar fyrir JEEP 6 tommu hækkun passar fyrir TJ, JK. XJ Verð 45,000kr. voru of langir fyrir mig:
Front lift coils for 2-Door Jeep JK, TJ/LJ, XJ and 4-Door Jeep JK Wranglers
Synergy coils offer excellent off road performance while preserving ride quality
Progressively wound; keeps spring from coming unbound at suspension droop
Progressively wound spring eliminates annoying spring clanking found on most suspension kits
Feature frequency balanced and tuned spring rates to maximize suspension performance on and off road
Suspension components feature an abrasive-resistant black powder coat finish for maximum durability and corrosion resistance
Springs are designed to give the advertised amount of lift with use of aftermarket front bumpers & winches.
Sold in Pairs
Part # Jeep JK Recommended Tire Size
8063-60 4-Door Jeep JK 6.0" Front Lift Springs 40" (42" w/ high fenders & proper bump stop spacers)
http://www.polyperformance.com/Synergy- ... il-Springs
Jeep TJ/LJ
8063-60 Jeep TJ/LJ 6.0" Front Lift Springs 38" (40" w/ high fenders & proper bump stop spacers)
Part #
Jeep XJ
8063-60 Jeep XJ 4.5 " Front Lift Springs 35" (37" w/ high fenders & proper bump stop spacers)
Part # APPROXIMATE LIFT HEIGHT
(2 DR JK) APPROXIMATE LIFT HEIGHT
(4 DR JK) SPRING TYPE FREE LENGTH
8063-60 7.0" 6.0" LINEAR 22.000" 9.300"
Notes:
Spring free length increases with lift height for compatibility with longer extended shock lengths.
Lift heights listed for JK are for models with gas engines. Expect approximately 1" less lift on diesel models.
Lift heights listed for TJ/LJ and XJ are for models with the 4.0L engine. Expect approximately 0.5"-1" more lift on 4 cylinder models.
For JK's with stock wheels or wheels with close to stock backspacing, 1-1/2" wheel spacers are recommended.
For JK's with 35" tires, 3" bump stop spacers are recommended. With high fenders, shorter bump stop spacers can be used.
For JK's with 37" tires, 4" bump stop spacers are recommended. With high fenders, shorter bump stop spacers can be used.
For 2 Door JK's with 5.5" of lift or more, the Synergy Long Arm System is recommended.
Made In USA
Síðast fært upp af Rikki þann 30.mar 2015, 22:11.
