Warn Spil til sölu – M8000
skf
Skráður: 13.maí 2010, 17:29
Fullt nafn: Sæmundur K. Finnbogason
Postfrá skf » 07.aug 2014, 19:07
Circa 10 ára gamalt Warn spil til sölu. Á sleða. Fjarstýring fylgir ásamt öllum köplum sem þarf til að tengja við rafgeymi.
Toggeta 8.000 pund / 3.600 kg.
Verð: 90.000
Skoða skipti á gæða tvíhendu (flugu stöng) - (Sage, G Loomis, RL Winston, o.s.frv.).
Sími 892 9949 / saemundurkf@gmail.com
Frekari upplýsingar
• Warn Part Number: PN 20910 CE (12V DC) 80' wire rope and hawse fairlead
• Rated Line Pull: 8000 lbs. (3630 kgs.) single-line
• Motor: 12V 4.8 hp, Series Wound
• Remote Control: Remote switch, 12' (3.7m) lead
• Geartrain: 3-Stage Planetary
• Gear Ratio: 216: 1
• Lubrication: Aeroshell #17
• Clutch (freespooling): Sliding Ring Gear
• Brake: Automatic Direct Drive Cone
• Drum Diameter/Length: 2.5"/9.0" (6.4cm/23cm)
• Weight: 74 lbs. (34 kgs.)
• Wire Rope: 80', 5/16" diam. (24m, 8mm diam.)
• Fairlead for PN 20910: Hawse
• Recommended Battery: 650 CCA minimum for winching
• Battery Leads: 2 gauge, 72" (1.83m)
• Finish: Argent Gray Po
