HID Xenon vs. LED Bar
Johnboblem
Skráður: 11.nóv 2010, 09:04
Fullt nafn: Stefán Þór Sigfússon
Bíltegund: Defender 130
Postfrá Johnboblem » 18.sep 2013, 10:04
Er að skoða ljós á bílinn hjá mér.
Það kemur til greina að panta 42" Led bar eða 9" HID Xenon ljós. Info um ljósin eru hér fyrir neðan. Menn meiga alveg segja sína skoðum hvort er betra.
■LED Power: 240W
■ Operating Voltage: 10-30 DC
■Waterproof rate: IP 67
■80pcs*3w high intensity LEDS
■ Body Color: Black,White
■Color Temperature: 6000K
■Material:Diecast aluminum housing
■Lens material:Toughed glass
■Mounting Bracket: Alu firm bracket
■30000 hours above life time .
■Dimensions:41.5 inch
■LUM:Appro 75-90LUM/w
■Beam angle: Flood spot beam combo (*8F/64S/8F)
■Theoretical Lumens Output: 24000 LM
■Operating Lumens Output: 21600 LM
■ Amp Draw(DC): 20A /12V , 10A / 24V
■ The suitable design for heating elimination.
■ The high performance of tight waterproof,dustproof,quakeproof.
■Weight: 5.7kg (Per Unit Included The Box)
■Size:1119.2x78.4x86.5mm
■2 Years Warranty
■Package included:
1PC 42inch 240W LED Light Bar
2PCS Mounting Brackets
9" 75W HID Xenon
■Model: 909A-EURO
■Rated output power: 75w +/-3w
■Rated operating voltage: 9v-12v DC
■Output voltage: 105v +/- 17v
■Lens: PMMA Poly(methyl methacrylate),
■Material:Plastic
■Housing: High lmpact ABS
■Reflector: Die-Cast Aluminium
■Ballast: Slim type built-in
■Bulb: H3/6000K Xenon Bulb
■HID Bulb Life Time: over 2500 hours
■SIZE: 9 inch
■ Theoretical Lumens Output: 6000 LM
■ Operating Lumens Output: 5400 LM
■ Current draw: 6.25A/ 12V.
■ Light Pattern: 60° (Euro Beam)
■ Operation temperature -40°C ~ 105°C
■ Unit Dimensions: 275 x 255 x 180 mm
■ Unit weight: 1.80kg Approx.(with box)
■Package included:
2PCS 9" HID DRIVING LIGHTS
2PCS Protector Lens Covers
1PC Wiring Harness
Re: HID Xenon vs. LED Bar
Postfrá jongud » 18.sep 2013, 10:41
Ef maður kaupir svona risastóra LED-slá þá er maður að setja öll eggin í sömu körfuna, ef sláin verður fyrir hnjaski þá er allt ljósadæmið farið.
Ef maður kaupir kastara þar sem hægt er að kaupa stakt stykki er hægt að endurnýja einn ef hann skemmist.
Ars
Skráður: 24.sep 2012, 20:50
Fullt nafn: Arnar Sverrisson
Postfrá Ars » 18.sep 2013, 10:47
Eg var með svona Xenon kastara hjá mér og líkaði alls ekki við þá þetta var allt of mikið punkt ljós þannig að ég skipti í hella Xenon kastaranna sem eru bæði dreifður og spotti.þeir eru allger snild en kosta hvítuna úr.
ég er hrikalega spentur fyrir LED barinu. Ég færi klárlega í það ef ég væri að velja mér ljós.
Arnar
Skráður: 01.feb 2010, 21:44
Postfrá Hjörturinn » 18.sep 2013, 10:52
Hvernig er það með svona ljós sem hitna ekkert, er þetta ekki hætt að lýsa um leið og það fer að skafa eitthvað og klammast snjór framaná þetta?
Bara pæling.
Tollinn
Skráður: 29.mar 2013, 22:24
Fullt nafn: Þorvaldur Einarsson
Postfrá Tollinn » 18.sep 2013, 10:54
Hjörturinn wrote:Hvernig er það með svona ljós sem hitna ekkert, er þetta ekki hætt að lýsa um leið og það fer að skafa eitthvað og klammast snjór framaná þetta?
Bara pæling.
Finnst þetta reyndar pæling sem vert er að skoða. Það hlýtur að vera einhver smá hiti frá þessu, er það ekki?
kv Tolli
Aparass
Skráður: 25.sep 2011, 21:29
Fullt nafn: Guðni Þór Scheving
Postfrá Aparass » 18.sep 2013, 11:02
Hitnar reyndar alveg slatta og það er gott að taka þetta í sundur einu sinni á ári eða svo og skipta um kælikremið í þeim því þá leiðir hitinn betur út aftan á ljósinu.
Led ið og það sem til þarf er á álplötu sem er síðan skrúfuð í bakhliðina á kastaranum, kælikrem þar á milli og hitinn sleppur síðan þar út að mestu en það bráðnar samt alveg af þeim að framan.
kjartanbj
Skráður: 06.jún 2011, 18:30
Fullt nafn: kjartan Björnsson
Bíltegund: Ford Ranger
Postfrá kjartanbj » 18.sep 2013, 11:22
Led Bar klárlega, gríðarlegur munur á ljósmagni , lítil orkunotkun og maður hreinsar bara af ef það skyldi koma snjór á þetta
myndi samt ekki mounta þetta eins og er á myndinni þarna fyrir ofan , þetta verður að vera framaná , annars er maður bara að lýsa upp snjókomu/rigningu
Eiður
Skráður: 06.mar 2011, 16:07
Fullt nafn: Eiður Smári Valsson
Bíltegund: Patrol Y61
Postfrá Eiður » 18.sep 2013, 11:53
ef díóðustöngin er frá þessum http://www.rigidindustries.com/ þá er hægt að fá mismunandi litaðar hlífar framan á stangirnar og þar á meðal gula litinn sem að á að vera bestur
Johnboblem
Postfrá Johnboblem » 18.sep 2013, 12:41
Takk fyrir svörin :)
Dúddi
Skráður: 13.feb 2010, 12:57
Fullt nafn: rúnar ingi árdal
Postfrá Dúddi » 18.sep 2013, 15:21
Hvað er gjaldið a svona 42 tommu priki?
Postfrá Stebbi » 18.sep 2013, 20:04
Bara pæling.
Ætlar þessi misskilningur ekkert að fara að hætta. Allt þetta drasl hitnar svínslega, Xenon pera hitnar svo mikið að hún nær að svíða leðurhanska og svona Led hitnar mun meira en margan grunar. Tók á svona led ræmu í dag sem er 14.4w per meter og var hún í álhúsi. Ekki séns að snerta álið það var svo heitt.
Eiður
Postfrá Eiður » 18.sep 2013, 20:57
ég er með skratti öflugt höfuðljós (petzl ultra fyrir þá sem þekkja) það hitnar helling hvort sem er á mesta styrk eða ekki
Postfrá olei » 19.sep 2013, 00:33
Öll* orkan sem ljós taka fer í að framleiða hita og þá gildir einu hvort um er að ræða hefðbundna glóperu, halogen,LED, HID eða hvað þetta heitir.
Hitamyndunin í þessari LED stöng er því 240W og 75W í HID ljósunum.
* Örlítil agnarögn af orkunni fer væntanlega í að knýja ferðalag ljóseindanna sjá:
https://en.wikipedia.org/wiki/Photon
Hvað varðar spurninguna - hvort er betra?
Ég geri ráð fyrir því að það fari alfarið eftir fyrirhugaðri notkun á þessum ljósum.
Navigatoramadeus
Skráður: 04.nóv 2012, 19:39
Fullt nafn: Jón Ingi Þorgrímsson
Bíltegund: Cruiser
Staðsetning: Álftanes
Postfrá Navigatoramadeus » 19.sep 2013, 08:27
Bara pæling.
held að þessi skilningur stafi frá "árdögum" xenon-ljósa, menn skiptu út 100W+ kösturum fyrir 21-35W xenon nema 21-35W xenonljós lýsti á við 100W halogen en margfalt minna afl/wött til að bræða snjóinn, þetta light-bar er 240W og þó ljósnýtni led sé ca 4-5x meiri en halogen fara samt rúm 90% af þessum 240W í hita en afgangurinn í sýnilegt ljós svo þetta þarf góða kælingu (heat sink) sem fæst með bakhliðinni/málmhúsinu til að leiða varmann, ef ekki væri fyrir það myndu þessar led-perur endast stutt.
light-barið er með virk 21600 lumens sem er svipað og 900-1000W halogenpera svona til samanburðar.
við vorum að fikta með svona 50W led-smd (surface mounted diode) og byrjuðum á að prófa birtuna af henni ÁN kæliplötu og hún sprakk/bráðnaði eftir ca 5 sekúndur en þvílík birta :)
við erum með 35W xenonljós sem köfunarljós og þau hitna ss um rúm 30W (þurfa að losa þá orku) og það er nóg til að ylja manni vel á puttunum í kafi.
svona useless info, meðalmaður gefur frá sér um 100W af hita að jafnaði yfir sólarhringinn, mv að hann nýti 90% af orkunni sem hann innbyrðir.
venjulegur rassahitari í sæti er um 30-50W.
Johnboblem
Postfrá Johnboblem » 19.sep 2013, 09:48
Dúddi wrote:Hvað er gjaldið a svona 42 tommu priki?
Það er um 250USD. Svo er 25,5% sem fer ofna á það. Þetta er svona 40.000 heimkomið.
http://www.ebay.com/itm/190897060300?ss ... 1423.l2649
Postfrá Freyr » 19.sep 2013, 20:00
Navigatoramadeus
Bíltegund: Cruiser
Postfrá Navigatoramadeus » 19.sep 2013, 20:05
Freyr wrote:.
I
AgnarBen
Skráður: 10.mar 2010, 10:30
Fullt nafn: Agnar Benónýsson
Postfrá AgnarBen » 19.sep 2013, 20:33
Hvernig lýsa þessi LED ljós, ég veit að ljósmagnið er mikið og ég geri ráð fyrir að þetta sé "dreifigeisli" en er hægt að fá einhverja punktvirkni í þessi ljós ?
p.s Ég er með 55W Xenon kit sem ég mixaði í gamla Hella Rallye 3000 kastara og þeir bræða ágætlega af sér.
Agnar Benónýsson
Jeep Cherokee 39,5"
Fordinn
Skráður: 03.feb 2010, 21:47
Fullt nafn: Mikkjal Agnar Þórsson
Postfrá Fordinn » 19.sep 2013, 21:37
Ég er með svona ljos á fjorhjolinu... þetta er fyrst og fremst flóðljós.... það á að heita punkt geisli i þessu enn þetta kastar ekki ljosi framm likt og góðir kastarar. td er eg med HID ljos á hjálminum til að fá lysingu lengra framm fyrir mig. það er hægt að fá þessi ljos niður i mjog litil sem henta td á hliðar og aftan á bíla og veita góða flóðlýsingu kringum bilinn.
Postfrá villi58 » 19.sep 2013, 22:11
Þessi Led-ljós, Led Bar eru mjög góð sem vinnuljós en draga mjög stutt.
Eiður
Postfrá Eiður » 20.sep 2013, 00:15
það fer allt eftir gæðum, það er ekki hægt að alhæfa að LED ljós séu alltaf með lélega drægni það fer aðalega eftir speglunum ef þú verslar hjá þekktu merki þá borgaru meira en færð það sem þú borgaðir fyrir...
Postfrá villi58 » 20.sep 2013, 12:06
AgnarBen wrote:Hvernig lýsa þessi LED ljós, ég veit að ljósmagnið er mikið og ég geri ráð fyrir að þetta sé "dreifigeisli" en er hægt að fá einhverja punktvirkni í þessi ljós ?
Ég mixaði í svona kastara og er að taka það úr núna, lýsti út um allt engin drægni.
Varst þú með perur með hlíf eða bara H 3 ?
s.f
Skráður: 08.feb 2010, 20:50
Fullt nafn: steinþór friðriksson
Postfrá s.f » 20.sep 2013, 17:10
ég er með svona HID 9" euro beam á bínum hjá mér og þetta eru bestu ljós sem ég hef haft
AgnarBen
Postfrá AgnarBen » 20.sep 2013, 20:37
Ég var með H3 og þetta lýsir mjög vel áfram. Hái geislinn á IPF tveggja geisla kösturunum mínum (110/170W) lýsti samt aðeins lengra held ég en ljósmagnið á Xenon ljósunum er að öðru leiti nokkuð svipað, kannski meira ef eitthvað er.
Agnar Benónýsson
Jeep Cherokee 39,5"
Postfrá ellisnorra » 05.okt 2013, 12:03
Flott að sjá led bar hér:
http://www.youtube.com/watch?v=on7dSpsm ... j_uohycX_P
á 8:10
haffiamp
Skráður: 21.jan 2012, 22:15
Fullt nafn: Hafþór Ægir Þórsson
Bíltegund: Terrano II 36"
Postfrá haffiamp » 05.okt 2013, 23:00
elliofur wrote:Flott að sjá led bar hér:
á 8:10
Þú meinar á 6:10.... þetta er flott ljós
En það sem Kjartanbj sagði um staðsetninguna á ljósi, það er alveg sama hvar ljósin eru staðsett, þau lýsa alltaf upp úrkomu fyrir framan bílinn, ég vil bara hafa ljósin þannig að þau nái ekki að lýsa upp húddið,þ.e.a.s ef ljós er sett á þak
Postfrá ellisnorra » 05.okt 2013, 23:41
Afsakið já, 6:10, typo :)
