TS: yaesu FT-2800m
gummibp
Skráður: 30.nóv 2012, 22:54
Fullt nafn: guðmundur bjarni pálmason
TS: yaesu FT-2800m
Postfrá gummibp » 09.apr 2013, 23:05
yaesu FT-2800m lítið notuð með helstu stöðvum verð 45Þ
8489714 Gummi
PRODUCTION DISCONTINUED IN 2009 AND REPLACED WITH FT-2900R
FT- 2800M Heavy-Duty 144 Mhz FM Transceiver
High power output, a huge, easy-to-read display, and one-touch WIRES™ Internet Linking Access capability are yours with the rugged new FT-2800M!
65 Watts Power Output
Four selectable power output levels are provided: 65/25/10/5 Watts. The power selection may be stored into memory, allowing you to conserve power while using strong local repeaters.
Excellent Receiver Performance
The FT-2800M’s receiver front end features Yaesu’s renowned Advanced Track Tuning RF input filtering, which affords outstanding protection from Intermodulation distortion.
CTCSS and DCS Encode/Decode Built In
For easy repeater access, or silent monitoring of busy channels, both CTCSS and DCS (Digital Code Squelch) Encoder/Decoder circuits are built in. CTCSS and DCS configuration data may be stored independently in each memory channel. A “Split Tone” mode also allows operation on systems where CTCSS and DCS are used separately on the repeater uplink/downlink.
Extensive Memory System
The FT-2800M provides a total of 221 memory channels, including 200 “regular” memories, ten pairs of band-limit memories, and an instant-recall “Home” channel you can dedicate to a frequently-used repeater or simplex frequency. Memories can store repeater shift information, CTCSS/DCS data, power output level, scanning status (“Skip”), and Alpha-Numeric labels.
gummibp
Re: TS: yaesu FT-2800m
Postfrá gummibp » 16.apr 2013, 16:37
