2x 1982 Hilux
Pero
Skráður: 22.okt 2011, 21:17
Fullt nafn: Per Gudmund Tofsrud
Bíltegund: 3x Hilux, 91 Pajero
Staðsetning: Norway
2x 1982 Hilux
Postfrá Pero » 15.maí 2012, 12:18
Hey, here are some pictures of my Toyotas.
I live in Norway which is why I write in English because maybe not everyone here understands Norwegian, even though I know some do;)
My first truck, sold an bought back a few years later.
And my orange one (stock, well used)
The white one is 2.4 diesel, runs on 33" tyres and lockers fornt and rear + power steering and hydraulic brake booster. The orange is 2.0 petrol, no mods.
Planing to build one of them to snowdriving. But have not decided who I will be using. Whether its best to have diesel or petrol.
If anyone has some good advice to the suspension and other modifications, speak out :) Want to use 38".
Óskar - Einfari
Skráður: 01.feb 2010, 08:29
Bíltegund: Toyota
Re: 2x 1982 Hilux
Postfrá Óskar - Einfari » 15.maí 2012, 12:49
Hello Pero and welcome :)
Nice to see a stock 82 body hilux :) there are not many left here in stock condition, if any at all. There are few however with this body that are modified.
The best way, also what requires most work and there fore more expensive. Is to replace the leaf spring suspension with a coil spring suspension front and rear but at the same time kepping overal lift as little as possible. For coil spring suspension the most populary way is to build 4-link rear suspensionusing components from LandCruiser 80. I bet someone here might even have drawings/blueprints for you of the mounts and arms that need to be fabricated. For front suspension I think many are using LC70 front suspension, even in some cases with the whole front axle assembly.
Keeping the stock suspension and lifting the body is also an option, its an easier way but the suspension will not be as good.
We prefer to keep lift at minimum, some even modify their trucks for 38-44" tires using no lift at all and I believe this is very well possible and has even been done before on a truck like yours.
Good luck!
Regards
Óskar Andri
birgthor
Skráður: 02.mar 2010, 22:05
Fullt nafn: Birgir
Re: 2x 1982 Hilux
Postfrá birgthor » 15.maí 2012, 12:56
Try to find out which has the better frame and than use the best from each :)
Kveðja, Birgir
Pero
Staðsetning: Norway
Re: 2x 1982 Hilux
Postfrá Pero » 15.maí 2012, 13:01
I love the old Hilux body ;) I was thinking about 2" lift maby? Coil springs would be fun to try out. Its plenty of cheap LC70 parts in this country. Long wheelbase, is that something to think about?
Thanks for the encouragement and help :)
Pero
Staðsetning: Norway
Re: 2x 1982 Hilux
Postfrá Pero » 15.maí 2012, 13:02
birgthor wrote:Try to find out which has the better frame and than use the best from each :)
Both have actually pretty good frames :)
birgthor
Fullt nafn: Birgir
Re: 2x 1982 Hilux
Postfrá birgthor » 15.maí 2012, 20:39
These are awesome pickups if you keep them low. Change the bigger one and keep the other original for town driving.
My opinion is like I said keeping them low, cut the fenders and move the front axle forward.
For longer traction move the back axle back.
It depends on your walled what suspension you should make, springs in front and air inn back or coilover all around.
Disel is for the better in my opinion :)
Kveðja, Birgir
Pero
Staðsetning: Norway
Re: 2x 1982 Hilux
Postfrá Pero » 15.maí 2012, 21:13
Not having a thick wallet, but i dont want to only do some bodylifting.
Ok, i will keep it as low i can with out the wheels rubbing the bodywork and frame. Where to by air springs?
The front leaf springs on the diesel hilux is very saggy so the 33" rubbing against the body with full flexing. So i need something else all around anyway. Cutting the firewall and maby move the bodymounts back some inches. If i mount the back leaf spring in front i also move the front axel forwards. But i do not like the ride comfort of leaf springs.
I found out that the LC70 front axel have the same measurements as the Hilux.
4:88 is ok on 38"? I have a turbo waiting for the diesel engine.
-Hjalti-
Skráður: 07.feb 2010, 21:22
Fullt nafn: Hjalti Sigurðsson
Re: 2x 1982 Hilux
Postfrá -Hjalti- » 15.maí 2012, 23:36
Yes Lc70 axle and Hilux axles are the same
Toyota 44"runner
Arctic cat M8000 162"
Pero
Staðsetning: Norway
Re: 2x 1982 Hilux
Postfrá Pero » 16.maí 2012, 06:40
:D Perhaps the easiest is to buy a whole LC70 and take all the front suspension parts out of it. And perhaps be lucky enough to get a good 2.4TD on the purchase.
Óskar - Einfari
Bíltegund: Toyota
Re: 2x 1982 Hilux
Postfrá Óskar - Einfari » 16.maí 2012, 12:39
4.88 or 5.29
For 38" tires with the 2,4 diesel I think you should go with the 5.29 gears, it is weaker but lower gears are better for deep snow and difficult conditions. The SingleCap however is really light so maybe 4.88 will work fine.... im not really sure. I would avoid 5.71 gears, its much weaker (it's strength tough really depends on how it is adjusted, I have never used these gears myself but it seems that great care must be taken when they are adjusted if they are to last). I would also consider some sort of differential locker options if your truck does not already have it. You might get stock toyota E-locker to fit into a standard 8" axle with little modification. ARB, No-spin, torsen and many other automatic lockers are also fine. Maybe you could even find a LC70 with a stock e-locker?
Pero
Staðsetning: Norway
Re: 2x 1982 Hilux
Postfrá Pero » 16.maí 2012, 13:01
I shall consider 5.29 if 4.88 is not low enough. It has a Lock Right auto lockers front and rear today. However, selectable front would be an advantage.
Pero
Staðsetning: Norway
Re: 2x 1982 Hilux
Postfrá Pero » 24.okt 2012, 12:21
35" 0"lift
AT405 test
Need more lift. ca 2"
Pero
Staðsetning: Norway
Re: 2x 1982 Hilux
Postfrá Pero » 24.okt 2012, 16:26
Have booked full paint in January.
The beadlock wheels are borrowed from my other toy;) This one is not going to be for snow driving.
birgthor
Fullt nafn: Birgir
Re: 2x 1982 Hilux
Postfrá birgthor » 24.okt 2012, 17:24
Keep the photos flowing, this is a good looking toy collection you got there :)
Kveðja, Birgir
Pero
Staðsetning: Norway
Re: 2x 1982 Hilux
Postfrá Pero » 24.okt 2012, 19:26
Not so many interesting pictures but it's something
Assisting a hilux with a flat battery
Beadlock rims
Pero
Staðsetning: Norway
Re: 2x 1982 Hilux
Postfrá Pero » 24.okt 2012, 19:32
washer inside the frame
Big Red
Skráður: 07.mar 2012, 12:17
Re: 2x 1982 Hilux
Postfrá Big Red » 04.jan 2013, 20:05
And how is this project coming along?
787-2159
reyktour
Skráður: 25.sep 2011, 17:13
Re: 2x 1982 Hilux
Postfrá reyktour » 04.jan 2013, 23:40
Flott project.
Knald paa
Pero
Staðsetning: Norway
Re: 2x 1982 Hilux
Postfrá Pero » 14.jan 2013, 18:57
Have had to repair more than I building. Ruined a diferensial up front before christmas.
Mounted an LC 70 rear LSD diff front and new TG cromemolybden CV joint.
Everything inside is new now
Finally proper snow
-Hjalti-
Re: 2x 1982 Hilux
Postfrá -Hjalti- » 14.jan 2013, 21:44
I would love to have that much snow here !
Toyota 44"runner
Pero
Staðsetning: Norway
Re: 2x 1982 Hilux
Postfrá Pero » 24.okt 2013, 10:00
New wheels :D I hope the snow comes.. !
37x12.5-15 12.5x15 rims
2013-10-21 17.33.07.jpg (145.95 KiB) Viewed 5697 times
2013-10-19 11.24.39.jpg (180.32 KiB) Viewed 5697 times
2013-10-21 17.33.22.jpg (133.89 KiB) Viewed 5697 times
And new springs
2013-10-04 23.16.59.jpg (124.71 KiB) Viewed 5697 times
sonur
Skráður: 17.okt 2010, 01:29
Fullt nafn: Elías Guðmundsson
Re: 2x 1982 Hilux
Postfrá sonur » 24.okt 2013, 10:54
I love those new rims!!
and I love lited pickuptrucks
Elli 6921247
Nissan terrible 1991 v6 38"
hjalz
Skráður: 09.jan 2011, 15:10
Fullt nafn: Hjálmar Guðjónsson
Bíltegund: ford explorer
Re: 2x 1982 Hilux
Postfrá hjalz » 25.okt 2013, 12:31
Very nice !
