Öflugur og nettur vinnu-ljóskastari með hleðslurafhlöðu.
Verð 9.900
Material:Aluminum alloy
Emitter Type:LED
Total Emitters:1
Power:10W
Color BIN:White
Rate Voltage:100~240 V
Luminous Flux:900LM
Chip Working Voltage:7.4V
Color Temperature:6000 K
Wavelength:No nm
Connector Type:Wired
ApplicationL:Outdoor working light
Features:Rotate 360 degrees lighting
Other:Application Lightweight and portable to carry; Widely used in project lighting, emergency repairing lighting, outdoor camping lighting, etc.; Charging time: 5 hours; Working time: 6 hours; Built-in 4400mAh Li-ion battery, voltage: 7.4V; With charging light indication, red to green for full charged, Charging and discharging protection;
Waterproof level: IP65; Constant current work
Packing List:
1 x Floodlight
1 x AC power charger adapter (110~240V / 2-flat-pin plug / 90cm-cable)
1 x Car charger (12~24V /110cm-cable)
Product size:16.5cm(L) x 16cm(W) x 18cm(H)
LED Kastari 10W með rafhlöðu
Johnboblem
Höfundur þráðar - Innlegg: 228
- Skráður: 11.nóv 2010, 09:04
- Fullt nafn: Stefán Þór Sigfússon
- Bíltegund: Defender 130
- S-LED-1576_7.jpg (88.91 KiB) Viewed 2081 time
- S-LED-1576_6.jpg (106.32 KiB) Viewed 2081 time
- S-LED-1576_5.jpg (137.87 KiB) Viewed 2081 time
- S-LED-1576_4.jpg (91.92 KiB) Viewed 2081 time
- S-LED-1576_3.jpg (98.41 KiB) Viewed 2081 time
- S-LED-1576_2.jpg (88.84 KiB) Viewed 2081 time
- S-LED-1576_1.jpg (92.96 KiB) Viewed 2081 time
Síðast breytt af Johnboblem þann 08.apr 2015, 14:10, breytt 2 sinnum samtals.
Re: LED Kastari 10W með rafhlöðu
Fylgja helsðslutæki og batterí með. Ég hef áhuga á þessu ef að það fylgja hleðslutæki fyrir bæði 12 og 220V :)
Johnboblem
Það er innbyggð rafhlaða, 220v helðslutæki og 12v hleðslutæki.
