jeep grand cherokee zj/zg 93 to98 5.2 v8 parts and price
chris92026
Skráður: 20.nóv 2014, 18:22
Fullt nafn: Christophe Perrin
Postfrá chris92026 » 06.jan 2015, 14:46
93 grand Cherokee European model sell part or trade ,can ship small parts for free or deliver to sellfoss for a fee
chris 8945407 text
or in the forum
WILL CONSIDER ANY offert
A/C Compressor sold
A/C Condenser 4300 kr
A/C Evaporator 3600 kr
AC Line Single 1600 kr
Air Cleaner sold
Antenna Mast 1000 kr
Arm Rest ALL 4 1200 kr
Brake Booster 3600kr
Brake Caliper 4300 kr
Brake Hub & Spindle Pressed 6000 kr
Brake Master Cylinder 2500
Bumper Rear Rubber 9000 kr
Cam Shaft 4500 kr
Control Arm 4500 kr
Crankshaft 7700 kr
Cylinder Head 5.2 v8 6000 kr
Dash Pad 3600 kr
Distributor 6000 kr
Distributor Cap 1400 kr
Door (window,motor door lock,door panel,switch) 8000 kr driver door sold
Door Handle Inside 800 kr
Door Handle Outside 1000 kr
Door Latch 1800 kr
Door Hinge 1100 kr
Door Panel Inside 1300 kr
Drive Shaft Front 4X4 6000 kr
Exhaust Manifold 2500 kr
Fan Relay 700 kr
Fan Blade sold
Fan Clutch No Blade sold
Fender bad
Fuel Injector each 2200 kr
Fuel Pump Elec sold
Fuel Tank 4000 kr
Lift Gate Cylinder each 1500 kr
Mirror Remote 3400 kr
Seat Belt 1800 kr
Seat Bucket( no motor or switch)left or right 3400 kr
Seat Motor 4500 kr
Shifter Assembly 3700 kr
Speedometer 3400 kr
Speedometer Cable sold
Spindle With Out/Axle Bearing Hold
Spindle With/ Axle Bearing Hold
Steering Center Link 3900 kr
Steering Column Tilt 8200 kr
Steering Hose Power 1500 kr
Steering Pump Power sold
Sun Visor 1200 kr
Thermostat Housing sold
Throttle Body 9300 kr
Throttle Cable 2300 kr
Tie Rod End Each bad
Timing Chain nfs
Timing Chain Cover 3100 kr
Timing Gear nfs
Trailer Hitch rusted
Trailing Arm sold
Trans Cross member sold
Transmission sold
Torque Converter sold
Turn Signal Switch 3100 kr
Water Pump sold
Window Motor Power 4500 kr
Windshield Washer Pump 1500 kr
Windshield Washer Tank 1500 kr
Windshield Wiper Motor 4500 kr
Wiper Arm 900kr
Wiring Harness 12000 k
Yoke Rear End sold
Gas Cap 700 kr
Gauge 2100 kr
Glass Back Stationary 5000 kr
Glass Door 6600 kr
Glass Quarter 6600 kr
Glass Vent 3400 kr
Glass Windshield 11000 kr
Grille 6200 kr
Header Panel Bare sold
Headlight Switch 1900 kr
Heater Control 6200 kr
Heater Core sold
Heater Motor 4600 kr
Hood 9800 kr
Hood Hinge 1000 kr
Hood Latch 2300 kr
Hood Release Cable 2300 kr
Horn 900 kr
Ignition Switch 2300 kr
Intake Manifold 6900 kr
Síðast breytt af chris92026 þann 08.apr 2015, 22:27, breytt 8 sinnum samtals.
Biggz
Skráður: 16.des 2014, 20:03
Fullt nafn: Birgir Örn Ragnarsson
Bíltegund: Grand Cherokee ZJ
Staðsetning: Kópavogur
Re: jeep grand cherokee zj
Postfrá Biggz » 06.jan 2015, 21:42
dose the car have over head console? what is the condition of the tires?
chris92026
Postfrá chris92026 » 07.jan 2015, 15:04
Yes it has the overhead console, I can post a picture tomorrow. The tires are not in good shape, and the wheels are not for sale.
Hjörturinn
Skráður: 01.feb 2010, 21:44
Postfrá Hjörturinn » 07.jan 2015, 15:09
Does it by any chance have a manual transmission?
chris92026
Postfrá chris92026 » 08.jan 2015, 12:03
no automatic
chris92026
Postfrá chris92026 » 17.jan 2015, 11:07
tail gate ,rear bumper,starter,alternator,tranmission ,tranfert case, are sold
Otri
Skráður: 10.jún 2012, 17:23
Fullt nafn: Otri Smárason
Bíltegund: Cherokee 35"
Postfrá Otri » 19.jan 2015, 21:40
Do you have a picture of brake master cylender
aravil
Skráður: 11.júl 2013, 02:28
Fullt nafn: Sölvi Már Benediktsson
Staðsetning: Rvk
Postfrá aravil » 26.jan 2015, 17:05
Hi, do you have the rear lower control arms?
grudzien21
Skráður: 14.apr 2014, 14:09
Fullt nafn: Michael Smietana
Bíltegund: jeep cherokee
Postfrá grudzien21 » 26.jan 2015, 17:22
birgirn
Skráður: 29.maí 2011, 19:52
Fullt nafn: Birgir Nielsen
Postfrá birgirn » 26.jan 2015, 19:29
How much for front seats?
chris92026
Postfrá chris92026 » 26.jan 2015, 21:29
Both front seats with the electric motors for 12,000 isk
Grudzien21, I will call you about the header panel and shipping tomorrow.
Síðast breytt af chris92026 þann 27.jan 2015, 20:48, breytt 1 sinni samtals.
chris92026
Postfrá chris92026 » 05.feb 2015, 18:06
grudzien21
8000 isk plus shipping for header panel
magnum62
Skráður: 19.aug 2011, 17:10
Fullt nafn: Magnús Guðmundsson
Bíltegund: Izusu Trooper 3.0 l
Re: jeep grand cherokee zj 93 to98 5.2 v8 parts and price
Postfrá magnum62 » 12.feb 2015, 03:43
How wide are those weel rims and how much?
chris92026
Postfrá chris92026 » 09.apr 2015, 21:19
those are 15x8
i have some 15x10 with 35 bf g if you like
Síðast fært upp af chris92026 þann 09.apr 2015, 21:19.
