38 "tires questions
Sunde
Skráður: 22.des 2013, 11:49
Fullt nafn: Martin Sunde
Bíltegund: Hilux 3,0 38"
38 "tires questions
Postfrá Sunde » 22.aug 2014, 07:59
Hello
Has anyone here experience with the tire Interco Trxus STS Radial size 38x15,50R15?
I wonder to try this in Norway, as a pure summer deck.I running 38 "AT 405 in winter.
Skráður: 06.feb 2010, 10:43
Re: 38 "tires questions
Postfrá ellisnorra » 22.aug 2014, 09:13
They say this size of trxus has be known to go flat with a explotion, even on high speed and the ribbing out next to the rim. Very bad if this happen, specially on front axle due to you never know where your car goes with a surprise like that.
Sunde
Postfrá Sunde » 22.aug 2014, 09:30
Hey thanks for the reply.
It's not good, if this happens while driving.
I am looking for a summer tires 38x15.50 R 15 anyone here know of good tires produced in this size?
Om vinteren bruker jeg 38x15.50R15 AT405.
Jeg kan bruke dette på sommeren og. men problemet er at det slites fort ned og er glatt både pga varme og regn
mhh
Skráður: 31.júl 2014, 18:17
Fullt nafn: Móses Halldórsson
Bíltegund: y60
Postfrá mhh » 23.aug 2014, 10:22
Try Toyo 37,5 14,5R15 they are very good summer tires.
Fordinn
Skráður: 03.feb 2010, 21:47
Fullt nafn: Mikkjal Agnar Þórsson
Postfrá Fordinn » 23.aug 2014, 10:41
Eg har brukt Toyo 38" under Ford F-250 i 4-5 år. Den bilen er 3500kg og disse dekkene har funkera veldig bra. Blir sikkert 100.000 km på dem til slutt.
Og en stor plus er ad de har veldig sterke og tjukke sider.
Sunde
Postfrá Sunde » 23.aug 2014, 15:36
you have the link to the toyo 38 "tire? I can not find toyo 38" I find it only in 20 " :-(
Fordinn
Postfrá Fordinn » 23.aug 2014, 20:00
Dekkjastærð Burðarþol Erl. vörunr Munsturdýpt (mm) Heildarhæð (mm) Heildarbreidd (mm) Samþykktar felgubreiddir
LT235/85R16 120P 360440 14 81 24 6.0-6.5-7.5
38x13.50R18LT 126Q 360380 17 96 37 8.5-11.0-11.0
38x13.50R20LT 124Q 360390 17 96 37 8.5-11.0-11.0
LT285/70R18 127Q 360590 15 87 29 7.5-8.5-9.5
31x10.50R15LT 109Q 360490 15 79 27 7.0-8.5-9.0
33x10.50R15 114P 360470 15 83 28 7.0-8.5-9.0
33x12.50R15LT 108P 360100 17 84 33 8.0-10.0-11.0
33x13.50R15LT 109Q 360290 17 84 35 8.5-11.0-11.0
35x13.50R15LT 114Q 361000 17 88 37 8.5-11.0-11.0
37x14.50R15LT 120Q 360260 17 93 40 10.0-12.0-12.0
LT245/75R16 120P 360450 14 78 25 6.5-7.0-8.0
LT255/85R16 123P 360460 15 85 26 6.5-7.0-8.0
LT265/75R16 123P 360320 15 81 27 7.0-7.5-8.0
LT285/75R16 126P 360280 15 84 28 7.5-8.0-9.0
LT305/70R16 124P 360110 16 84 31 8.0-9.0-9.5
LT315/75R16 127Q 360230 17 89 33 8.0-8.5-10.0
LT385/70R16 130Q 360480 17 96 40 10.0-11.0-12.0
LT265/70R17 121P 360130 15 81 27 7.0-8.0-8.5
LT285/75R17 121P 360430 15 87 29 7.5-8.0-9.5
LT295/70R17 128P 360360 15 85 30 8.0-8.5-9.5
35x12.50R17LT 125Q 360310 17 88 34 8.5-10.0-11.0
37x13.50R17LT 131Q 360270 17 94 37 8.5-11.0-11.0
LT275/70R18 125P 360120 15 85 28 7.0-8.0-8.5
LT285/75R18 129P 360420 15 89 29 7.5-8.0-9.5
LT315/70R18 127Q 360560 17 91 33 8.5-9.5-10.0
33x12.50R18LT 118Q 360340 17 84 32 8.5-10.0-11.0
35x12.50R18LT 123Q 360090 17 89 34 8.5-10.0-11.0
37x13.50R18LT 124Q 360300 17 94 36 8.5-11.0-11.0
38x15.50R18LT 128Q 360180 17 96 40 11.0-12.0-13.0
LT275/65R20 126P 360410 15 88 28 7.5-8.0-9.5
LT315/60R20 125Q 360510 17 89 32 9.5-9.5-11.0
33x12.50R20LT 114Q 360330 17 84 32 8.5-10.0-11.0
35x12.50R20LT 121Q 360240 17 89 33 9.0-10.0-11.0
37x13.50R20LT 127Q 360220 17 94 36 8.5-11.0-11.0
38x15.50R20LT 125Q 360190 17 96 40 11.0-12.0-13.0
40x15.50R20LT 130Q 360370 17 101 40 11.0-12.0-13.0
33x12.50R22LT 109Q 360520 15 84 31 8.5-10.0-11.0
35x12.50R22LT 117Q 360540 17 89 33 8.5-10.0-11.0
37x13.50R22LT 123Q 360210 17 94 36 8.5-11.0-11.0
40x15.50R22LT 127Q 360200 17 101 40 11.0-12.0-13.0
37x13.50R24LT 120Q 360350 17 94 35 8.5-11.0-11.0
I dag er ikke snakke om 38" da er snakke om LT385/70R16 for 16 tomme felger.
Forhandleren pa Island er : http://benni.is/Dekk/Jeppar/Vetrar-heil ... ountry_MT/
Prisen pa 4 stk ligger round 25000 norske kroner.
Sunde
Postfrá Sunde » 09.jan 2015, 16:09
Hi
Is there anyone here who run this Toyo tire and could have taken some pictures and shared experiences on the deck?
nobrks
Skráður: 31.jan 2010, 21:12
Postfrá nobrks » 09.jan 2015, 18:53
Go for the Toyo As summer tire, only heard good storys about it.
Long lasting tire, easy to balance. 37 or 38"
snöfli
Skráður: 03.sep 2010, 19:21
Fullt nafn: Lárus Elíasson
Bíltegund: Patrol Y61
Postfrá snöfli » 09.jan 2015, 19:57
Good till the end. No surprises.
