Calix Vélahitari 750W
joipalli
Skráður: 19.júl 2011, 15:25
Fullt nafn: Jóhannes Páll Friðriksson
Postfrá joipalli » 25.sep 2013, 11:06
Til sölu:
Kröftugur en lítill vélarhitari
Módelnr. PH750 750W for 12-18 litre cooling system
Heimasíða Calix
http://www.calix.se/en/products/engine-heaters
The solution in these cases is a Calix PH. This heater is connected to the cooling system outside the engine block using a hose connection (20 mm). As with the insertion heater, the PH is based on the self-circulation principle and fulfils all requirements that can be set for a heating system. Our thoroughly-tested PH engine heaters are equipped with an overheating guard and a thermostat and are supplied complete with a plug-in connector and connecting cable.
The new model with designation PH (Professional Heater), has some product
improvements such as the size, which simplify the installation. The new PH is also
equipped with a rubber sealing for increased service life and reliability.
Our thoroughly-tested new PH heater is equipped with overheating protection
and a thermostat. The PH is delivered as before as a complete kit with heater,
cables, bracket, etc. or as only the heater with bracket.
Verð: 15.þús.kr.
Jóhannes
6982663
Síðast breytt af joipalli þann 27.sep 2013, 08:50, breytt 2 sinnum samtals.
dazy crazy
Skráður: 13.feb 2011, 15:12
Fullt nafn: Dagur Torfason
Bíltegund: Kangoo og Ferguson
Staðsetning: Skagafjörður
Re: Calix Vélahitari 750W
Postfrá dazy crazy » 25.sep 2013, 13:47
hvað er verðið á þessu hjá þér? Er þetta ekki hentugt á dráttarvélar?
joipalli
Postfrá joipalli » 25.sep 2013, 15:52
Jú þetta hentar vel fyrir dráttarvélar og aðrar stærri vélar.
Verðið er 15 þús.kr.
Notendur á þessu spjallborði: Astivalur og 1 gestur
