Lightweight and small size.
Easy to fit and connect.(2 bolt fixing , 2 wire design.)
Using a plunger-type of fuel supply way, suction stronger,oil supply more stable
Tubing Interface 8mm Plug in connector
Model: HEP-02A
Installation hole distance :6.7CM
Flows: 70(L/h)
Currents: 1.2A
Voltage: 12V
Pressure : 0.032-0 .045 MPA
Output Pressure: 3-6 PSI
Inlet and Outlet diameter: 8mm
