6 mánaða gamall bílmagnari til sölu kostar nýr um 38þ fæst á 17þ er í síma 8473497 hér eru uppl um hann
Gothic Series 2-Channel Car Amplifier
RMS Power Rating:
4 ohms: 220 watts x 2 chan.
2 ohms: 280 watts x 2 chan.
Bridged, 4 ohms: 560 watts x 1 chan.
Max power output: 1250 watts
MOSFET power supply
Pulse width modulation circuitry
Remote bass level input (remote level control included)
LED power indicators
Bass Boost (0-24 dB bass boost at 45 Hz)
Tri-Mode capable
2/1 channel operation
2 Ohm stereo, 4 ohm mono stable
Preamp RCA outputs
3-Way system protection circuitry (short, thermal and overload)
Gunmetal gray anodized finish with chrome accents
Heavy duty aluminum alloy heatsink
RCA level inputs
Screw terminals
Low level inputs (200mV-8V)
Variable high-pass filter (50-500 Hz, 12 dB/octave)
Variable low-pass filter (30-500 Hz, 12 dB/octave)
Subsonic Filter (12 dB at 30-175 Hz)
Frequency response: 10-30,000 Hz
Dimensions: 12-7/8"L x 10-5/8"W x 3"
Bílmagnari til sölu SELT!
Höfundur þráðar - Innlegg: 455
- Skráður: 31.jan 2010, 23:55
- Fullt nafn: Hjalti Þór Stefánsson
- Staðsetning: Mosó
Það er belja að taka framúr þér!!! Hva ef þú ert að flýta þér snýktu þá far....
Notendur á þessu spjallborði: Engir skráðir notendur og 23 gestir
