(TS) GPS SIMRAD CP32
Hansi
Skráður: 01.feb 2010, 20:28
Fullt nafn: Hans Ragnar Þór
Bíltegund: Toyota LC 80
Postfrá Hansi » 27.aug 2010, 14:40
Til sölu GPS Simrad CP 32
Stór skjár, mjög öflugt tæki
Tilboð óskast
S. 896-5973 - Hans
Specs.
CP32 Technical Specifications:
Power supply:
10-32 V dc
Power drain:
7-10 Watts
Environment:
0 to 50oC,Waterproof (USL 46 CFR and IP55)
Dimensions:
144x252x70 mm/1.5 Kg (5.8x10x2.8”/3Lbs)
Display: 6" large LCD display in TFT colour
6-inch, 320x240 pixels STN transflective
Interfacing:
2 ports in/out NMEA 0180/0182/0183/
dual station/IS11
Alarm/log:
Alarm or 200 pulses/nm
GPS section
Receiver type:
8 channel parallel, C/A code, all-in-view track keeping
Filter:
8 state Kalman filter
Accuracy:
Position: 8 m RMS, Speed: 0.1 kn, Heading 1o
Speed filter:
10 settings
Update:
1 - 2 second interval typical
Dynamics:
Velocity: 600 Km/h, Acceleration: 10m/S2
Mark/WP:
999 with name or depth (12 characters)
Tracks:
9 tracks, 256 points each, selectable interval
Lines:
500 lines/line sections
Routes:
30 with up to 99 WP each
GPS antenna type:
Quadrifilar Helix
Dimensions
L: 230, D: 38 mm/150 g.
Mounting:
1”14 thread (standard US)
Cable:
Max. 10m RG58 (standard) Max. 30m RG213
(option)
Echo sounder section
Frequency:
50 200 kHz. user selectable
Output power:
500 watts RMS (4,000 w PP)
Measuring units:
(tct) Meters, feet and fathoms.
Depth range display:
3 to 3000 units in 23 steps and auto
Depth range:
Up to 350m at 200 kHz and 800 m at 50 kHz
Pulse length:
50 kHz=1,0 ms, 200 kHz=0,25 ms or 1,0 ms.
Max. ping rate:
2 ping per second
Alarms:
Fish, max. and min. depth
Zoom mode:
Bottom and VRM expansion: 3 to 50 units.
Split screen:
Depth and A-scope.
Depth and bottom expansion.
Depth and VRM expansion.
Event markers:
At current ping
Image speed:
True distance or time (3 steps),
1 step/ping and freeze
Signal threshold:
User selectable on/off
Fish detection:
White line discrimination
Temperature:
Transducer or NMEA
Speed (water):
Transducer or NMEA
Hansi
Re: (TS) GPS SIMRAD CP32
Postfrá Hansi » 20.sep 2010, 19:42
en til
joisnaer
Skráður: 03.feb 2010, 16:03
Postfrá joisnaer » 20.sep 2010, 23:05
er íslandskort í þessu og verðhugmynd í mrfozzy_hf@hotmail.com
Land Rover Defender tdi300 næstum 44" breyttur
Hansi
Postfrá Hansi » 21.sep 2010, 08:52
Það er ekki sérstakt íslandskort í því. Skjóttu bara á mig tilboði ef þú hefur áhuga. Þetta er flott tæki á jöklum sór og góður skjár.
Kv. Hansi
Hansi
Postfrá Hansi » 02.des 2010, 19:58
ennþá til
LeibbiMagg
Skráður: 27.nóv 2010, 14:16
Fullt nafn: Leifur Ingi Magnússon
Staðsetning: Þórshöfn
Postfrá LeibbiMagg » 25.des 2010, 17:09
hvað er þetta gamalt tæki og hvað myndiru sirka vilja fá fyrir það?
Nissan patrol 46" breyttur en stendur á 44" með teingdamömmubox
Trooper 3.0 TDI '99 -seldur
Santa fe '03 -seldur
Toureg V6 '03 -seldur
Mazda3 sport 2.0 '04 -seldur
Camaro Z28 '01 -seldur
Civic 1600Vti '99 -seldur
Kv Leibbarinn
Hansi
Postfrá Hansi » 26.des 2010, 13:47
LeibbiMagg wrote:hvað er þetta gamalt tæki og hvað myndiru sirka vilja fá fyrir það?
þetta er ca. 8-10 ára gamalt. Ltur mjög vel út, sér ekkert á því. Var fast í jeppa lengi vel.
Fæst á 15þús.
LeibbiMagg
Postfrá LeibbiMagg » 26.des 2010, 15:32
það er ekkert sérstakt islandskort í þessu er það ekki eithvað sem er hægt að upgrada bara eða er þetta eithvað grunn kort bara sem er í þessu? hvað fylgir með þessu tæki ? snúra og loftnet eða bara tækið ? ef það fylgir með þessu snura allavega þá tek ég tækið ...en ég var að spá sko ég er með garmin svepp get ég notað hann við þetta tæki?
Kv Leibbarinn
Hansi
Postfrá Hansi » 26.des 2010, 17:59
það er með því snúra, það var allavega sveppur á bílnum hjá mér sem það var tengt við, held garmin sveppurinn gangi við það.
LeibbiMagg
Postfrá LeibbiMagg » 26.des 2010, 19:08
okey en festing fyrir tækið ég er bara með svona garmin festingu á mælaborðinu eða er festing með þvi...? ég ætla að taka það samt ég hringi bara í þig á eftir og spyr þig betur uti þetta takk:)
Kv Leibbarinn
