Til sölu nýtt Superwinch 8500 punda spil .
Description:
Superwinch's LP8500 8,500 lb winch is designed to accommodate entry-level buyers shopping for excellent value. Meeting the rugged demands of off-road and utility use, the LP8500 introduces price conscious buyers to the quality, power, and performance advantages of the Superwinch brand.
Rated line pull = 8,500 lbs.
Winch motor = 4.5 HP series wound
Control = Rubber 12' lead hand held
Gear train = 3 -Stage planetary
Gear reduction ratio = 235:1
Braking action = Mechanical automatic load holding
Drum size = 2.5" (67mm) diameter x 8.8" (224mm) length
Cable = 5/16" x 94' (7.9mm x 29m)
Fairlead = Heavy duty powder coated hawse
Remote control = included
Overall dimensions = (LxWxH) 21.3" L x 6.3" W x 8.6" H
Verð 150.000-
Þórarinn
s.864 0984
TS.nýtt Superwinch 8500 punda spil ...
Höfundur þráðar - Innlegg: 696
- Skráður: 25.jún 2011, 19:45
- Fullt nafn: Þórarinn Sverrisson
