Land Rover Discovery II , TD5 2,5 Diesel - SELDUR !!!
ulver
Skráður: 30.mar 2014, 13:56
Fullt nafn: Robert Wielgus
Postfrá ulver » 03.maí 2014, 18:15
***************** S O L D !!! ************************
Disco 2 TD5 99 for sale. 2,5 ltr Diesel , 212.000 km
NEW HEAD - changed 26.04.14 - cost ~400.000 ISK !
24 month warranty !!!
Inspection : 2015
Timing chain !
Cruise Control.
New front screen window with heating , 4 wheels drive with Central Diff-lock - extra difflock lever mounted.
2 inch body lift (5 cm higher) ,
Front and rear differential steel protection covers , front halogens with fog lights , rear working light (works manually and with rear gear).
Two wheels sets summer and winter tires on alloy rims. Winter tires on spikes , two seasons , allmost new , cost me around 130k two years ago.
New head with new valves and head gasket set , fuel pressure regulator , injector washers ,front brake discs ,all brake pads . Last month the brake pipeline was changed for copper so ... no more rust :)
Full working Webasto heater !
Voltage meter - I replaced clock for a volts meter so anytime you wish you can see the true voltage incoming from battery and alternator :). Good mod in winter time , no more dead battery , always you can see the condition and you can charge when is necessary.
Dashboard camera recorder.
Snorkel.
Differentials breathers extended.
EGR valve removed. I still have it so I can put it back if you want but now cleaner air incoming to engine increasing power and giving longer life ;)
Wind deflectors.
All door locks and electric windows are working :)
No leaks ! I know is strange for Land Rover but it`s true , this one is not leaking ;) New oil in differentials.
Phone: 6658209 , 8950822
Price for exchange - 890.000,
The lowest price ... :) - if you can find something wrong / things to fix , then I can go to 700.000 minimum (cash) ,but ... first try to find anything :) . This car is in perfect technical condition , I spend a lot of money to fix all of broken things/parts. I`m not offering a bullshit so please not offer me bullshit like 500k also ;)
pictures: https://bland.is/classified/entry.aspx?classifiedId=2204639
Síðast breytt af ulver þann 15.maí 2014, 23:09, breytt 1 sinni samtals.
ulver
Re: Land Rover Discovery II , TD5 2,5 Diesel
Postfrá ulver » 15.maí 2014, 07:57
600.000 ISK. :) - this week only !!!
ulver
Re: Land Rover Discovery II , TD5 2,5 Diesel - SELDUR !!!
Postfrá ulver » 15.maí 2014, 23:09
SOLD !
