Hi,
Now that the snow has gone away, i fired up My lovely 2,9td musso. And almost everything in el. way was dead, My first thought was the alternator, since it was unplugged due to a bodylify.
I replugged the alternator but that did not help.
The things that do work is;
El. Mirrors,
Ext. And int. Light.
Horn.
Wipers but not the auto range,
And the fuel gauge.
The rest is dead, f.ex. The 4wd hi and lo, door lock, coupé fan etc...
Every thing did work when i parked it for about 4mounth ago, with the alternator unplugged.
Any ideas?
Ps.i'v checked the fuses next to the clutch pedal, in the fusebox above the left wheel and the small box attached to the battary. Is ther any more?
Regards Sami.
Almost Every Electric Things Are Gone.
Re: Almost Every Electric Things Are Gone.
- Minuscaple loose or not tight enaugh?
- Skráður: 30.jan 2010, 23:08
- Bíltegund: Suzuki Fox
- Staðsetning: Mosó
Hi Sami and welcome to the forum.
Please state your full name (Fullt nafn) in the user settings, here: ucp.php?i=172
Best regards,
Gisli.
Best regards,
Gisli.
sami/B wrote:Every thing did work when i parked it for about 4mounth ago, with the alternator unplugged.
Any ideas?
Regards Sami.
Check every ground connection you know of, maybe you loosen'd one up while lifting the body and forgot to reconnect. Easy way is to use jumper cables straight from the battery to ground the engine, chassis and body.
Höfundur þráðar - Innlegg: 21
- Skráður: 02.sep 2012, 19:33
- Fullt nafn: Sami Sven Abdesslam Belcaid
- Bíltegund: Musso 2.9TD -96
Stebbi wrote:Check every ground connection you know of, maybe you loosen'd one up while lifting the body and forgot to reconnect. Easy way is to use jumper cables straight from the battery to ground the engine, chassis and body.
Thank you, i will try that tomorow.
Can it be the ignition(?), the key switch? (don't know the correct word in english)
I have now tested to ground everything with jumpers. No succses :/
I just find somthing!
Fuse no 18. Is instantly burning. (Dont know how i missed that)
It's marked as "stics", "a/con" and " com/meter", what does that meen?
Notendur á þessu spjallborði: Engir skráðir notendur og 13 gestir
